Double up on convenience. The DUO Plus is a Type-C drive with a super-useful Type-A adapter. Eliminate worries as the intuitive integrated Type-A adapter works with your older devices that have Type-A connections. Now you can flexibly move data and free up space with superior speed and performance.
Either way is the right way
There's no wrong way to plug it in. Sporting the industry's exceptional USB Type-C technology, the DUO Plus plugs in right-side up every time - no flipping, no fumbling, no fuss. Transfer files with ease to your Type-C smartphones, tablet PCs, and laptops. -
Double your connectivity
One flash drive for many devices. Both USB Type-C and Type-A connectivity let you speedily free up device space with quick backups and file offloads due to fast read speeds up to 300 MB/s. Now you can add even more movies, music, and games. -
Tough & trusted
Files stay secure, almost anywhere you go. Samsung's leadership in flash memory makes the DUO Plus a trustworthy drive to store your valuable data. It works through it all with a waterproof, shock-proof, temperature-proof, magnet-proof, and X-ray-proof body.
- Samsung DUO Plus MUF-256DB - USB flash drive - 256 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1 / USB-C
- Storage Capacity
- 256 GB
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 256 GB
- Read Rate
- Up to 300 MB/s
- Interface Type
- USB 3.1 / USB-C
- Shockproof, magnetic-proof, water resistant, X-ray-proof, temperature-proof
- Limited warranty - 5 years
- 57.92 mm
- 18.33 mm
- 7.29 mm
- 7.7 g
- -25 °C
- 85 °C
