Samsung 256GB Duo Plus USB 3.1 Drive - Up to 300MB/s
Quicklinx: DRP0WS00 Mfr#: MUF-256DB/EU
Select:
  • 256GB
Double up on convenience. The DUO Plus is a Type-C drive with a super-useful Type-A adapter. Eliminate worries as the intuitive integrated Type-A adapter works with your older devices. You can flexibly move data and free up space with superior speed and performance.
  • Either way is the right way
    There's no wrong way to plug it in. Sporting USB Type-C technology, the DUO Plus plugs-in right side up every time - no flipping, no fumbling, no fuss. Transfer large files with ease to your Type-C smartphones, tablets, PCs and laptops.
  • Double your connectivity
    One flash drive for many devices. Both USB Type-C and Type-A connectivity, lets you quickly free up device space with fast backups and file offloads. You can add even more movies, music and games.
  • Tough & trusted
    Files stay secure, anywhere you go. The DUO Plus is a trustworthy drive to store your valuable data. It works through it all with a waterproof body.
Samsung DUO Plus MUF-256DB - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.1 / USB-C
Storage Capacity
256 GB
5-year warranty
USB flash drive
Storage Capacity
256 GB
Read Rate
Up to 300 MB/s
Interface Type
USB 3.1 / USB-C
Shockproof, magnetic-proof, water resistant, X-ray-proof, temperature-proof
Limited warranty - 5 years
57.9 mm
18.3 mm
7.37 mm
7.7 g
-25 °C
85 °C
