Samsung 24" G32A FullHD Odyssey Gaming Monitor
Quicklinx: GQW4WS00 Mfr#: LS24AG320NUXXU
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: HDMI, DisplayPort
£165.84 ex VAT
£199.00 inc VAT
165 Hz refresh rate and 1 ms response time makes it perfect for crisp and smooth gameplay - you'll appreciate that extra in fast-paced online titles like CS:GO or Valorant
AMD Freesync Premium technology takes care of screen tearing, blurring and other artefacts for smooth action in games, even if your framerate dips lower now and then
Full HD VA screen boasts sharp contrast, deep blacks and wide viewing angles, so it even looks great from the side
Fully adjustable stand lets you to get the viewing angle just right, so you can keep a healthy posture throughout your gaming marathons
This monitor has low blue light and is flicker free, so it goes easy on your eyes
  • Immersive viewing experience
    The Samsung Odyssey G3 offers a 24-inch Full HD display with a 3000:1 contrast ratio and 72% NTSC color gamut, delivering vivid colors and deep blacks for an immersive viewing experience.
  • Ergonomic design
    With height, pivot, swivel, and tilt adjustments, the Odyssey G3 ensures a comfortable viewing position tailored to your needs, enhancing productivity and gaming sessions.
  • Seamless gameplay
    Equipped with AMD FreeSync Premium and a 165 Hz refresh rate, this monitor provides a smooth gaming experience with low latency and a 1 ms response time.
  • Eye comfort features
    Flicker-Free technology and Eye Saver Mode reduce eye strain during long working hours or gaming sessions, making it easier to focus and remain productive.
  • Versatile connectivity
    Featuring HDMI and DisplayPort inputs, the Odyssey G3 connects to a wide range of devices, offering flexibility for entertainment and work setups.
Samsung Odyssey G3 S24AG320NU - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
23 kWh
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.2767 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
1 ms (MPRT)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100-240 V (50/60 Hz)
54.4 cm x 23.42 cm x 49.87 cm
4.5 kg
Display Type
Energy Class
Class E
23 kWh
Diagonal Size
24"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2767 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (MPRT)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Refresh Rate Optimizer, 3 Side Borderless Design
54.4 cm x 23.42 cm x 49.87 cm - with stand
4.5 kg
HDMI , DisplayPort 1.2 , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
16 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption (Max)
25 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.4 cm - depth: 23.42 cm - height: 49.87 cm - weight: 4.5 kg , Without stand - width: 54.4 cm - depth: 9.2 cm - height: 33.33 cm - weight: 3 kg
Shipping Width
63.6 cm
Shipping Depth
45.4 cm
Shipping Height
21.15 cm
Shipping Weight
6.6 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
