- Samsung C24RG50FZR - CRG5 Series - LED monitor - curved - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 31 kWh
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Voltage
- AC 100-240 V
- Black
- 54.78 cm x 24.26 cm x 43.05 cm
- 3.3 kg
- Display Type
- Energy Class
- Class F
- 31 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.5"
- Curved Screen
- Yes (1800R)
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Cinema Mode, Mega Dynamic Contrast Ratio, Black eQualizer, CustomColor Mode, FPS Mode, Flicker Free technology, RTS Mode, Eye Saver Mode, Low Input Lag, Super Arena Gaming UX, Screen Size Optimizer, Refresh Rate Optimizer, RPG Mode, AOS Mode
- Black
- 54.78 cm x 24.26 cm x 43.05 cm - with stand
- 3.3 kg
- DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+20
- Cables Included
- 1 x HDMI cable
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 21 kWh/1000h
- Power Consumption (Typical)
- 21 Watt
- Power Consumption (Max)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- Easy Setting Box
- Dimensions & Weight Details
- With stand - width: 54.78 cm - depth: 24.26 cm - height: 43.05 cm - weight: 3.3 kg , Without stand - width: 54.78 cm - depth: 9.07 cm - height: 32.63 cm - weight: 2.8 kg
- Shipping Width
- 61.2 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 39.1 cm
- Shipping Weight
- 4.9 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
