- Samsung T9 MU-PG1T0B - SSD - 1 TB - USB 3.2 Gen 2x2
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.2 Gen 2x2 - USB-C
- Data Transfer Rate
- 20 Gbps (USB 3.2 Gen 2x2)
- Password authentication, up to 3m to concrete drop protection
- Power Source
- USB bus
- Enclosure Colour
- Black
- 60 mm x 88 mm x 14 mm
- 122 g
- Localisation
- Europe
- 5-year warranty
- Capacity
- 1 TB
- 256-bit AES
- Interface
- USB 3.2 Gen 2x2
- 60 mm
- 88 mm
- 14 mm
- 122 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 2000 MB/s
- Internal Data Rate
- 2000 MBps (read) / 1950 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2x2 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Apple MacOS, Android, Windows
- Cables Included
- USB-C cable , USB-C to USB-A cable
- UL, TUV, VCCI, BSMI, CB, IC, FCC, KC, RoHS2, EAC, RCM, BIS, UKCA
- Enclosure Colour
- Black
- Localisation
- Europe
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
