Wings on your mobile! Samsung’s Spinpoint M8 series employs advanced format technology (AFT) that raises the data storage density per unit area, enabling efficient and convenient data storage. It operates on a high-performance 3 gigabits per second SATA interface, provides an eight megabyte buffer memory and incorporates EcoSeek and NoiseGuard features for minimal noise levels. A redesign of the overall structure ensures enhanced shock resistance to protect the disc from physical fracture and data loss. Fast and reliable with a 5400rpm spin speed and 8MB buffer, Samsung’s Spinpoint M8 series is the perfect choice for use in mobile computing applications such as notebooks
- Samsung SpinPoint M8 HN-M101MBB - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- Load/unload technology, NoiseGuard, SilentSeek technology, Native Command Queuing (NCQ), Tunnel Magneto-resistive Recording (TMR) Head Technology, Perpendicular Magnetic Recording (PMR), Flying On Demand (FOD) Technology, EcoTriangle, EcoSeek, S.M.A.R.T.
- 70 mm x 100 mm x 9.5 mm
- 107 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 1 TB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Buffer Size
- 8 MB
- 70 mm
- 100 mm
- 9.5 mm
- 107 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 145 MBps
- Seek Time
- 12 ms (average)
- Average Latency
- 5.6 ms
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 3 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H
- 5 °C
- 55 °C
- 5 - 90% (non-condensing)
- Shock Tolerance
- 325 g @ 2ms half-sine pulse (operating) / 750 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 1.5 g @ RMS (random) (operating)
