Samsung 1TB 980 PRO PCIe M.2 SSD
Quicklinx: G6XWWS00 Mfr#: MZ-V8P1T0BW
Form Factor: M.2 2280
Capacity: 1TB, 1TB
Interface: PCI Express 4.0 x4 (NVMe)
Type: Internal hard drive
£86.50 ex VAT
£103.80 inc VAT
Unleash the power of the Samsung PCIe 4.0 NVMe SSD 980 PRO for your next-level computing. Leveraging the PCIe 4.0 interface, the 980 PRO delivers double the data transfer rate of PCIe 3.0 while being backward-compatible for PCIe 3.0 for added versatility.
Powered by Samsung custom Elpis Controller for PCIe 4.0 SSD, the 980 PRO is optimized for speed. It delivers read speeds up to 7,000 MB/s, making it 2 times faster than PCIe 3.0 SSDs and 12.7 times faster than SATA SSDs. The 980 PRO achieves maximum speeds on PCIe 4.0 and may vary in other environments.
  • A winning combination
    Designed with hardcore gamers and tech-savvy users in mind, the 980 PRO offers high-performance bandwidth and throughput for heavy-duty applications in gaming, graphics, data analytics, and more. It's fast at loading games so you can play more and wait less.
  • Efficient M.2 SSD
    The 980 PRO comes in a compact M.2 2280 form factor, which can be easily plugged into desktops and laptops for maximum board design flexibility. The drive is suitable for building high-performance computing systems due to its optimized power efficiency.
  • Reliable thermal control
    High-performance SSDs usually require high-performance thermal control. To ensure stable performance, the 980 PRO uses nickel coating to help manage the controller's heat level and a heat spreader label to deliver effective thermal control of the NAND chip.
  • Smart thermal solution
    Embedded with Samsung's cutting-edge thermal control algorithm, the 980 PRO manages heat on its own to deliver durable and reliable performance. To minimize performance fluctuations in the long haul, Samsung's Dynamic Thermal Guard technology maintains the 980 PRO's temperature at optimal levels.
  • Samsung Magician software
    Unlock the full power of the 980 PRO with Samsung Magician's intuitive yet advanced optimization tools. Monitor drive health, optimize performance, protect valuable data, and receive important updates with Samsung Magician to ensure you're always getting the best performance out of your SSD.
Samsung 980 PRO MZ-V8P1T0BW - SSD - 1 TB - PCIe 4.0 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
M.2 2280
PCIe 4.0 x4 (NVMe)
Buffer Size
1 GB
TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, Low Power DDR4 SDRAM Cache, NVM Express (NVMe) 1.3c, Samsung V-NAND 3bit MLC Technology, Samsung Elpis Controller, S.M.A.R.T.
22.15 mm x 80.15 mm x 2.38 mm
9 g
5-year warranty
Intel Next Unit of Computing 12 Enthusiast Mini PC - NUC12SNKi72VA, 13 Extreme Kit - NUC13RNGi5, 13 Extreme Kit - NUC13RNGi7
1 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 4.0 x4 (NVMe)
Buffer Size
1 GB
22.15 mm
80.15 mm
2.38 mm
9 g
Performance
SSD Endurance
600 TB
Internal Data Rate
7000 MBps (read) / 5000 MBps (write)
4KB Random Read
22000 IOPS
4KB Random Write
60000 IOPS
Maximum 4KB Random Write
1000000 IOPS
Maximum 4KB Random Read
1000000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
PCI Express 4.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
6.2 Watt (average) , 8.9 Watt (maximum) , 0.035 Watt (idle)
Software Included
Samsung Magician Software
IEEE 1667
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
