The 870 QVO SSD offers an incredible upgrade for everyday PC users who want to ramp-up their desktop PC or laptop to large storage without compromising on performance.
Enhanced in everyway
Achieving the maximum SATA interface limit of high sequential speeds, the 870 QVO features improved random speed and sustained performance compared to the previous 860 QVO. Intelligent TurboWrite accelerates write speeds and maintains long-term high performance with a larger variable buffer. -
Enjoy max capacity
With the 870 QVO, users can now enjoy and thrive in the large SSD computing environment with an approachable price. -
Upgrade with ease
Upgrading to the 870 QVO is made easy for anyone with a desktop PC or laptop that supports a standard 2.5-inch SATA form factor. Enjoying this SSD is as convenient as plugging in the 870 QVO into a SATA slot.
- Samsung 870 QVO MZ-77Q1T0BW - SSD - 1 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Quad-level cell (QLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 1 GB
- TRIM support, Auto Garbage Collection Algorithm, Worldwide Name (WWN), TurboWrite Technology, Device Sleep support, Low Power DDR4 SDRAM Cache, Samsung MKX Controller, Samsung V-NAND 4bit MLC Technology, S.M.A.R.T., 256-bit AES, IEEE 1667
- 69.85 mm x 100 mm x 6.8 mm
- 46 g
- 3-year warranty
- Capacity
- 1 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 1 GB
- 69.85 mm
- 100 mm
- 6.8 mm
- 46 g
Performance
- SSD Endurance
- 360 TB
- Internal Data Rate
- 560 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 11000 IOPS
- 4KB Random Write
- 35000 IOPS
- Maximum 4KB Random Write
- 88000 IOPS
- Maximum 4KB Random Read
- 98000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 2.2 Watt (average) , 4 Watt (maximum) , 0.03 Watt (idle) , 0.003 Watt (sleep)
- Software Included
- Samsung Magician Software
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -45 °C
- Max Storage Temperature
- 85 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (non-operating)
- 20 g @ 20-2000 Hz
