Samsung 1TB 870 EVO 2.5 inch SATA 3 SSD
Quicklinx: G57KWS00 Mfr#: MZ-77E1T0B/EU
Form Factor: 2.5
Capacity: 1TB, 1TB
Interface: Serial ATA-600
Type: Internal hard drive
47 In Stock
£107.50 ex VAT
£129.00 inc VAT
The latest model of the world's best-selling SSD series has finally arrived. The 870 EVO inherits the legacy of Samsung's pioneering SSD technology, boasting upgraded performance, reliability and compatibility to suit the needs of anyone from content creators and IT professionals to everyday users.
  • Excellence in performance
    The 870 EVO achieves the maximum SATA interface limit of 560/530 MB/s sequential speeds. Everyday users can now enjoy professional-level SSD performance. Intelligent TurboWrite accelerates write speeds and maintains long-term high performance with a larger variable buffer.
  • Industry-defining reliability
    Providing up to 2,400 TBW the 870 EVO meets the industry's leading standards of reliability. It withstands tasks from everyday computing to 8K video processing and comes equipped with the latest 6th Gen. VNAND and MKX controller that ensure a stable host experience.
  • More compatible than ever
    The 870 EVO passed compatibility tests with major host systems and applications, including chipsets, motherboards, NAS and video recording devices. As the latest entry in the globally best-selling EVO series, the 870 EVO's proven versatility is compatible with any user's systems and tasks.
  • Upgrade with ease
    Upgrading to the 870 EVO is made easy for anyone with a desktop PC or laptop that supports a standard 2.5-inch SATA form factor. Enjoying this masterpiece SSD is as convenient as plugging in the 870 EVO into a SATA slot and letting the renewed migration software take care of the rest.
  • Samsung Magician software
    Make your drive work like magic. The new and improved Samsung Magician 6 software will keep your SSD in check. You can easily manage your drive with a wide range of useful tools to keep up with the latest updates, monitor the drive's health and status, or even enhance its performance.
Samsung 870 EVO MZ-77E1T0B - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
1 GB
TRIM support, sleep mode, Auto Garbage Collection Algorithm, Worldwide Name (WWN), TurboWrite Technology, 3-bit 3D V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung MKX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
45 g
5-year warranty
1 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
1 GB
69.85 mm
100 mm
6.8 mm
45 g
Performance
SSD Endurance
600 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
13000 IOPS
4KB Random Write
36000 IOPS
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.5 Watt (average) , 4.4 Watt (maximum)
Software Included
Samsung Magician Software
WWN, IEEE 1667
Limited warranty - 5 years / 600 TBW
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Form Factor: 2.5
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
