Highlights of the Samsung 19" SM943NW monitor
Screen: 19" widesceen (1440 x 900)
Brightness: 300 cd/m2
Contrast Ratio: 8000:1 (Dynamic)
Response time: 5ms
Connectivity: VGA
Energy efficient
With an ENERGY STAR certification and EPEAT Silver level compliance, this monitor is designed for eco-conscious performance, reducing power consumption and lowering energy costs. -
Vivid visuals
Experience vibrant, true-to-life colors with a 19-inch widescreen TFT active matrix display, supporting 16.7 million colors and a native resolution of 1440 x 900. The monitor's features enhance image quality for a superior viewing experience. -
Ergonomic design
The Samsung SyncMaster 943NW is designed for comfort and convenience, featuring a wall-mountable design with a 75 x 75 mm flat panel mount interface and adjustable H/V position controls for optimal viewing angles.
- Samsung SyncMaster 943NW - LCD monitor - 19"
- LCD monitor - 19"
- Native Resolution
- 1440 x 900 at 75 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 8000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Silver
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 43.9 cm x 18.5 cm x 36.8 cm
- 3.8 kg
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- TUV GS, DDC-2B, ISO 13406-2
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 19"
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 8000:1 (dynamic)
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 81 kHz
- Video Bandwidth
- 137 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour balance, gamma correction, colour temperature
- OSD Languages
- English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Turkish
- OSD-Digital Display Director, Sync on Green, MagicTune, MagicSpeed, MagicColor, MagicBright 3
- Silver
- 3.8 kg
- 1 x VGA - 15 pin HD D-Sub (HD-15)
Mechanical
- Tilt
- VESA Mounting Interface
- 75 x 75 mm
- Security lock slot (cable lock sold separately), wall mountable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 34 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Included Software
- Drivers & Utilities, Natural Color Pro
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80%
