Presenting high performance business monitors that suit both your vision and your budget. Series 40 monitors have a stylish design plus a high dynamic contrast ratio and fast response time along with exclusive Magic technologies to enhance your productivity. No matter how you look at it, the outlook is bright with Samsung Series 40 monitors.
Perfect high speed performance
With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience. -
Get into the details
The differences make all the difference. That's why the Samsung ultra-high 70000:1 Dynamic Contrast ratio automatic backlight adjustment creates deeper, more dramatic dark tones and brighter, more striking light tones. Now you can enjoy images that echo reality with rich, vivid colour and brilliant natural intensity. When it comes down to the details, conventional monitors simply pale in comparison. -
Perfect Viewing Experience with Magic Lux
Magic Angle creates the perfect viewing position when you are lying down. By recreating the image purity that you see when viewing the screen from the front, Magic Angle makes entertainment more comfortable. When returning to a normal viewing position, Magic Angle should always be turned off to ensure ocular comfort. -
Control brightness, conserve energy
Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco. -
A monitor that takes the initiative to share
With Samsung's Magic Return you never have to worry about your second monitor losing content. If the cable disconnects and the signal disappears, Magic Return automatically transfers the content from that screen to the other monitor before turning off. There's no magic here. We just have content sharing down to a science.
- Samsung SyncMaster B1940W - LCD monitor - 19"
- LCD monitor - 19"
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 70000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), tilt
- Black
- 44.3 cm x 19 cm x 33.7 cm
- 4.2 kg
- Microsoft Certification
- Compatible with Windows 7
- DDC-2B
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 19"
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 81 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Controls & Adjustments
- H/V position
- Sync on Green, power off timer, HDCP, MagicAngle, MagicEco, MagicBright 3
- Black
- 4.2 kg
- VGA , DVI-D
Mechanical
- VESA Mounting Interface
- 75 x 75 mm
- Wall mountable
- DDC-2B
- Power Supply
- Internal
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Shipping Width
- 44.3 cm
- Shipping Depth
- 29.5 cm
- Shipping Height
- 13 cm
- Shipping Weight
- 6.3 kg
