Samsung 128GB Fit Plus USB 3.1 - Black
Quicklinx: G6Z2WS00 Mfr#: MUF-128AB/APC
Capacity: 128GB
Interface: USB 3.1
£13.74 ex VAT
£16.48 inc VAT
The compact way to add big space. Plug in the FIT Plus to get secondary, upgraded storage for your devices, then leave it in to easily carry more files wherever you go. It stays out of your way and is so quick it keeps files at the ready, all with USB 3.1 speeds and trusted reliability.
  • Store more
    Extra storage that's always with you. The FIT Plus gives portability in a minimal profile, and is designed to seamlessly stay in your device, always ready for use. Keep it in laptops, smart TVs, and cars with reduced risk of accidental bumps or removal.
  • Quick and ready
    Save time, add space. Quick and convenient read speeds ensure transferring data never slows you down.
  • Tough & trusted
    Files stay secure, anywhere you go. FIT Plus is a trustworthy drive to store your valuable data. It works through it all with a waterproof, shock-proof, temperature-proof body.
Samsung FIT Plus MUF-128AB - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
128 GB
5-year warranty
USB flash drive
Storage Capacity
128 GB
Read Rate
Up to 400 MB/s
Write Rate
Up to 60 MB/s
Interface Type
USB 3.1
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
Limited warranty - 5 years
23.6 mm
7.3 mm
18.8 mm
3.1 g
-25 °C
85 °C
Capacity: 128GB
Interface: USB 3.1
Brand: Samsung
