A modern take on a classic. The next generation Bar Plus elevates the flash drive to an everyday essential, offering impressive speed and striking design. Fit to your hand, the metal unibody is pure minimalism in a drive that cleverly blends style, speed, and reliability.
Move files in a flash
Get your time back. Fast and convenient read speeds up to 300 MB/s with the USB 3.1 standard give you more time to work, play, watch, and create. -
Rugged refinement
As strong as it is stylish. The sturdy metal body keeps your data safe and intact, and the integrated keyring prevents accidental misplacement or loss. The Bar Plus is the ideal combination of stunning design and worry-free durability.
 - Samsung BAR Plus MUF-128BE3 - USB flash drive - 128 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB 3.1 Gen 1
- Storage Capacity
 - 128 GB
- Enclosure Colour
 - Champagne silver
 - 5-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 128 GB
- Enclosure Colour
 - Champagne silver
- Read Rate
 - Up to 300 MB/s
- Interface Type
 - USB 3.1 Gen 1
 - Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof, metal body, key ring loop
 - Limited warranty - 5 years
 - 15.6 mm
 - 11.7 mm
 - 40.01 mm
 - 10 g
 - 0 °C
 - 60 °C
