Samsung 1.9TB 2.5" 7mm TLC Sata 6Gbps 2GB Cache SSD
Quicklinx: FY4TWS00 Mfr#: MZ7LH1T9HMLT-00005
Marketing description is not available.
  • Robust durability
    Engineered to withstand the toughest conditions, this solid state drive boasts a shock acceleration tolerance of 1500 g and a vibration acceleration of 20 g, ensuring your data remains safe even in the most extreme environments.
  • Enhanced security
    With 256-bit AES hardware encryption, this SSD provides high-level security for your data, making it an ideal choice for sensitive information storage.
  • High capacity storage
    Offering a generous 1.92 TB capacity, this SSD meets the need for substantial storage space, allowing for extensive data collection and storage without the worry of running out of space.
  • Exceptional performance
    Achieve remarkable data transfer speeds up to 550 MBps read and 520 MBps write, complemented by a high 4KB random read of 98000 IOPS and write of 25000 IOPS, for swift and efficient data handling.
Samsung PM883 MZ7LH1T9HMLT - SSD - 1.92 TB - SATA 6Gb/s
Solid state drive - internal
1.92 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support, Power Disable Pin (Pin3)
69.85 mm x 100.2 mm x 6.8 mm
70 g
1.92 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Bytes per Sector
512
69.85 mm
100.2 mm
6.8 mm
70 g
Performance
Drive Writes Per Day (DWPD)
1.3
SSD Endurance
2733 TB
Data Transfer Rate Details
Serial ATA: 600 MB/s
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
4KB Random Read
98000 IOPS
4KB Random Write
25000 IOPS
Average Latency
40 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.3 watt (read) , 3.4 watt (write) , 1.3 watt (idle)
RoHS
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
