Samsung  19 INCH WIDE BLACK LCD MONITOR
Quicklinx: 7KBYWS00 Mfr#: LS19CLNSB/EN
Presenting high performance business monitors that suit both your vision and your budget. Series 20 monitors have a stylish design plus a high dynamic contrast ratio and fast response time along with exclusive Magic technologies to enhance your productivity. No matter how you look at it, the outlook is bright with Samsung Series 20 monitors.
  • Perfect high speed performance
    With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
  • Get into the details
    The differences make all the difference. That's why the Samsung ultra-high 70000:1 Dynamic Contrast ratio automatic backlight adjustment creates deeper, more dramatic dark tones and brighter, more striking light tones. Now you can enjoy images that echo reality with rich, vivid colour and brilliant natural intensity. When it comes down to the details, conventional monitors simply pale in comparison.
  • Feel the Effects of Colour
    Enhance images your way using Samsung's advanced ColourEffect feature. Open your eyes to a completely customised viewing experience as you play with photographic effects that match your mood. Choose from Aqua, Sepia, Green and Greyscale to interact with your display in a whole new way – namely, yours.
  • Perfect Viewing Experience with Magic Lux
    Magic Angle creates the perfect viewing position when you are lying down. By recreating the image purity that you see when viewing the screen from the front, Magic Angle makes entertainment more comfortable. When returning to a normal viewing position, Magic Angle should always be turned off to ensure ocular comfort.
  • Control brightness, conserve energy
    Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco.
Samsung SyncMaster E1920NW - Series 20 - LCD monitor - 19"
LCD monitor - 19"
Native Resolution
1440 x 900
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 70000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
44.3 cm x 18 cm x 37.5 cm
3.6 kg
DDC-2B
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Native Resolution
1440 x 900
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
MagicAngle, MagicEco, MagicBright 3
3.6 kg
VGA
Mechanical
Tilt
VESA Mounting Interface
75 x 75 mm
DDC-2B
Power Supply
Internal
Power Consumption (Typical)
35 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Shipping Width
44.3 cm
Shipping Depth
29.5 cm
Shipping Height
8.9 cm
Shipping Weight
4.7 kg
