Saitek Pro Flight Rudder Pedals
Quicklinx: 4B41WS00 Mfr#: PZ35
Complete your virtual pilot's controller setup and take flight simulation reality to the next level with the Pro Flight Rudder Pedals.
Control the rudder and toe brakes of your aircraft with your feet - just like real pilots. Adjustable, smooth action gives you optimum control and realism, and brings you even closer to the experience of flying a real aircraft.
Saitek Pro Flight Rudder Pedals - pedals - wired
Pedals
Wired
Adjustable tension, rudder control
Microsoft Certification
Works with Windows Vista
PC
Pedals
Wired
USB
1 x USB - 4 pin USB Type A
Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP
Software Included
Saitek Smart Technology (SST)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
PC
