Saitek Eclipse Mobile Mouse
Quicklinx: 7HDKWS00 Mfr#: EOV436010002/06/3
Robust in construction, the mobilemouse™ uses premium hard-wearing materials with a die cast frame, ensuring that the mouse will stand up to the most demanding of commuter or business use.
The eclipse mobilemouse features impressive technology and understated yet sophisticated good looks.
The low profile Scroll Ball allows for effortless 4-way scrolling with audible click feedback. Scroll up, scroll down, scroll at 45° or even through 360°. Easy to use with no cleaning required.
1600dpi laser technology ensures smooth operation on a variety of surfaces. Fully wireless, the mobilemouse utilizes 2.4GHz technology and a `nano-dongle' for an unobtrusive appearance and rock solid connection at all times.
mobilemouse features flexigrip™, an adjustable back leg which affords flexibility and in hand comfort, allowing you to achieve your preferred optimum glide height.
Eclipse mobilemouse - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
4
Movement Resolution
1600 dpi
Scrolling wheel (4-way), height adjustable, 360° scroll, flexigrip
Apple MacOS X, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
Mouse
Wireless Receiver
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
4
Movement Resolution
1600 dpi
1 x USB
