Ruckus 7025 Multimedia WiFi Wall Switch
Quicklinx: 972KWS00 Mfr#: 901-7025-WW01
  • IEEE 802.11n
The ZoneFlex 7025 integrates high speed 2.4 GHz 802.11n Wi-Fi technology with wired Ethernet ports into an elegant, inconspicuous and low-profile wall jack that fits into an electrical junction box. It's ideal for offering multiple connections into hotel guest rooms and university dormitories without multiple cables. It delivers high performance Wi-Fi coverage and four wired Ethernet connections and an additional pass-through port for digital phones that requires native access to an in-house PBX system.
Ruckus ZoneFlex 7025 Wi-Fi Wall Switch - radio access point - Wi-Fi
Radio access point
External
Worldwide
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
Throughput: 85 Mbps
Concurrent users: 100 , VoIP calls: 10
Power Over Ethernet (PoE) Supported
PoE
8.5 cm x 8.5 cm x 5.6 cm
140 g
Radio access point
8.5 cm
8.5 cm
5.6 cm
140 g
Enclosure Colour
White
Worldwide
External
Wireless
Data Transfer Rate
150 Mbps
Switching Protocol
Ethernet
Network / Transport Protocol
L2TP, PPPoE, FTP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
Frequency Band
2.4 GHz
Performance
Throughput: 85 Mbps
Status Indicators
Power, status
VLAN support, auto-uplink (auto MDI/MDI-X), manageable, IPv6 support, firmware upgradable, WISP mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Auto Traffic Classifier (ATC), Multiple SSID support, IPv4 support
Encryption Algorithm
AES, TKIP, WPA2, WPA-PSK
Authentication Method
RADIUS, LDAP, Basic Service Set Identifier (BSSID), Active Directory
IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Gain Level
2 dBi
3 x 100Base-TX - RJ-45 , 1 x 100Base-TX (WAN) , 1 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX (management)
PoE
50 °C
15 - 95% (non-condensing)
