Ring Video Doorbell  Pro 2 - Plug-in Adapter
Quicklinx: G87HWS00 Mfr#: B086QLM9BV
Type: Doorbell
Compatible With: Alexa
45 In Stock
£166.66 ex VAT
£199.99 inc VAT
With 1080HD video, two-way audio and customizable motion sensors, the new Video Doorbell Pro is most advanced doorbell yet.
Get instant alerts when visitors press your doorbell or trigger the built-in motion sensors, and see, hear and speak to anyone at your door from your smartphone, tablet or PC.
With an ultra-slim design and customizable faceplates, Ring Pro has a finish to match your home and your style.
  • Putting the pro in protection
    Video Doorbell Pro 2 is Ring's best-in-class doorbell for ultimate performance and protection. See and hear like never before with boosted HD+ video and crisp audio quality. Pinpoint movement with 3D Motion Detection. And with Alexa Greetings, Alexa can speak to visitors and accept deliveries when you can't get to the door. It's the first doorbell to run your front door.
  • Get the whole picture
    See more of who stops by and check in on package deliveries down low with Head-to-Toe HD+ Video in 1536p. You'll also never miss a thing, even in the dark or bad weather, with crystal-clear color night vision.
  • The best motion detection on the block
    Pinpoint motion and distance with 3D Motion Detection - the first feature of its kind, only available on Video Doorbell Pro 2.
Ring Video Doorbell Pro 2 - doorbell - 802.11a/b/g/n/ac - satin nickel - with plug-in adapter
Doorbell
Functions
Motion detection, camera
Power Source
Power adapter
Intelligent Assistant
Alexa
Bundled with
Plug-in adapter
Wireless - 802.11a/b/g/n/ac
Frequency Band
2.4 Ghz, 5 GHz
Supported Host Device OS
Android, iOS, Windows, MacOS
Camera
Audio - Day&Night
Satin nickel
1-year warranty
4.9 cm x 2.2 cm x 11.4 cm
Doorbell
Functions
Power Source
Power adapter
Bundled with
Plug-in adapter
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11a
Frequency Band
2.4 Ghz, 5 GHz
Weatherproof, instant alerts
Internet of Things (IoT)
Communications Technology
Wi-Fi
Alexa
Camera
Day & Night Functionality
Audio Support
Video Modes
1556p
3D Motion Detection, 2-way voice communication, Live View Control, noise-cancellation, Bird's Eye View, Colour Night Vision, people only mode, advanced pre-roll, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), Head to Toe Video
Software
Ring Protect (30 days trial)
Faceplate (satin nickel), installation kit, corner kit, security sticker
Satin nickel
Warranty
1-year warranty
12 Watt
4.9 cm
2.2 cm
11.4 cm
-20.5 °C
48.5 °C
Type: Doorbell
Brand: Ring
