Brand
Ring Video Doorbell  Pro 2 - Hardwired
Quicklinx: G87GWS00 Mfr#: 8VRCPZ-0EU0
Type: Doorbell
Compatible With: Alexa
£182.50 ex VAT
£219.00 inc VAT
Watch over your home in crystal-clear video, and see, hear and speak to visitors from anywhere. With instant mobile alerts and two-way talk, you can answer the door from your smartphone, tablet and PC.
  • Putting the pro in protection
    Video Doorbell Pro 2 is Ring's best-in-class doorbell for ultimate performance and protection. See and hear like never before with boosted HD+ video and crisp audio quality. Pinpoint movement with 3D Motion Detection. And with Alexa Greetings, Alexa can speak to visitors and accept deliveries when you can't get to the door. It's the first doorbell to run your front door.
  • Get the whole picture
    See more of who stops by and check in on package deliveries down low with Head-to-Toe HD+ Video in 1536p. You'll also never miss a thing, even in the dark or bad weather, with crystal-clear color night vision.
  • The best motion detection on the block
    Pinpoint motion and distance with 3D Motion Detection - the first feature of its kind, only available on Video Doorbell Pro 2.
Ring Video Doorbell Pro 2 - doorbell - 802.11a/b/g/n/ac - satin nickel
Doorbell
Functions
Motion detection, camera
Power Source
Hardwired
Intelligent Assistant
Alexa
Wireless - 802.11a/b/g/n/ac
Frequency Band
2.4 Ghz, 5 GHz
Supported Host Device OS
iOS, Android, Windows, MacOS
Camera
Audio - Day&Night
Satin nickel
1-year warranty
4.9 cm x 2.2 cm x 11.4 cm
Doorbell
Functions
Power Source
Hardwired
Wireless - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 Ghz, 5 GHz
Weatherproof, instant alerts
Internet of Things (IoT)
Communications Technology
Wi-Fi
Alexa
Camera
Day & Night Functionality
Audio Support
Video Modes
1556p
Live View Control, 2-way voice communication, Colour Night Vision, noise-cancellation, 3D Motion Detection, Bird's Eye View, people only mode, advanced pre-roll, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), Head to Toe Video
Software
Ring Protect (30 days trial)
Installation kit, security sticker, faceplate (satin nickel), corner kit
Satin nickel
Nominal Voltage
AC 16 - 24 V / DC 24 V
Warranty
1-year warranty
12 Watt
4.9 cm
2.2 cm
11.4 cm
-20.5 °C
48.5 °C
Type: Doorbell
Brand: Ring
Stock Status: In stock
