Ring Video Doorbell - Satin Nickel
Quicklinx: GL26WS00 Mfr#: B0931VRJT5
Type: Smart doorbell
Compatible With: Alexa, Alexa ready
Hurry, only 1 left in stock!
£83.33 ex VAT
£99.99 inc VAT
Watch over your home in crystal-clear video, and see, hear and speak to visitors from anywhere. With instant mobile alerts and two-way talk, you can answer the door from your smartphone, tablet and PC.
Never miss a visitor, or a package.
With these convenient features you can see what’s happening at your front door, get alerts when packages are left on your doorstep and set automatic responses for when you can’t answer the door.
Real-time notifications
Get notifications in real-time when visitors press your doorbell or trigger the built-in motion sensors.
Package Alerts
Receive alerts whenever a package is detected within your specified zone, an exclusive Ring Protect subscription feature.
Quick Replies
If you’re too busy to answer the door or just don't feel like answering, save time and use Quick Replies to respond with your choice of six preset messages.
Clear as day. And night.
See, hear and speak to anyone at your front door from your phone or tablet in crisp 1080p HD. With improved image sensors and sharp contrast, you’ll never miss a detail – even in the dark.
  • Answer the door from anywhere
    Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors.
  • Never miss a visitor
    Ring lets you customize your motion sensors, so you'll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock - day or night, rain or shine.
  • Home security at your fingertips
    Power your Video Doorbell with its built-in rechargeable battery, or connect it to your existing doorbell wiring for a non-stop charge.
Ring Video Doorbell - smart doorbell - 2nd generation - 802.11b/g/n - satin nickel
Smart doorbell - with camera
Integrated Sensors
Motion sensor
Integrated Components
Microphone, speaker, camera
Power Source
Hardwired, battery
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android, MacOS
Camera
Audio - Day&Night
Satin nickel
Image Colour Disclaimer
The displayed product image may be a different colour
1-year warranty
6.35 cm x 2.74 cm x 12.83 cm
Integrated Sensors
Motion sensor
Power Source
Hardwired, battery
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
iOS, Android, MacOS
2-way audio, instant alerts, weather-resistant, People Only mode 1080p resolution support
Camera
Day & Night Functionality
Audio Support
Video Modes
1080p
2-way voice communication, noise-cancellation, 160° field of view (horizontal), 90° field of view (vertical)
Rechargeable Battery
Rechargeable
Battery Included
Required Qty
1
Screws, USB charge cable, mounting tools, security sticker, faceplate (satin nickel), wedge kit, corner kit, adapter plate
Satin nickel
AC 8 - 24 V
Warranty
1-year warranty
6.35 cm
2.74 cm
12.83 cm
-20.5 °C
48.5 °C
Compatible With: Alexa ready
Brand: Ring
