Ring Video Doorbell - Satin Nickel
Quicklinx: D39MWS00 Mfr#: 8VR1S5-SEU0
Type: Doorbell camera
Compatible With: Alexa, IFTTT, SmartThings
Colours:
Hurry, only 1 left in stock!
£74.17 ex VAT
£89.00 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
Ring Video Doorbell
See, hear and speak to anyone at your door from your smartphone, tablet or PC. Works on every home - with or without a doorbell. Quick and easy self-install.
Answer the Door From Anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. Then use the free Ring app to see, hear and speak to guests from your smartphone, tablet or PC.
• Motion-activated alerts
• Crystal-clear 720HD video
• Two-way talk with noise cancellation
Never Miss a Visitor
Ring lets you customize your motion sensors, so you’ll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock – day or night, rain or shine.
• Custom motion zones
• Infrared night vision
• Lifetime purchase protection
Home Security at Your Fingertips
Power your Video Doorbell with its built-in rechargeable battery, or connect it to your existing doorbell wiring for a non-stop charge. It also comes with everything you need to install your Doorbell in just a few minutes, with no professional help required.
• Dual power options
• Simple installation and setup
• iOS, Android, Mac and Windows 10 compatible
A Ring of Security Around Your Home
With a Video Doorbell at your door and Stick Up Cams around the house, you can create a Ring of Security around your entire home, and get complete peace of mind for you and your family.
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
  • Answer the door from anywhere
  • Never miss a visitor
    Ring lets you customize your motion sensors, so you'll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock - day or night, rain or shine.
  • Home security at your fingertips
Ring Video Doorbell - doorbell camera
Doorbell camera
Functions
Motion detection, camera
Power Source
Hardwired, battery
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android, Windows, MacOS
Camera
Audio - Day&Night
Satin nickel
2 year warranty
6.17 cm x 2.21 cm x 12.65 cm
Doorbell camera
Functions
Power Source
Hardwired, battery
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Apple MacOS, Android, Apple iOS, Windows 10
Weatherproof, instant alerts 720p resolution support
Camera
Day & Night Functionality
Audio Support
Video Modes
720p
Motion Detection Technology, 2-way voice communication, 180° field of view
Motion Sensor
Automatic night vision, custom motion zones
Satin nickel
Nominal Voltage
DC 8 - 24 V
Warranty
2 year warranty
6.17 cm
2.21 cm
12.65 cm
-20 °C
48 °C
Compatible With: IFTTT
Compatible With: SmartThings
Brand: Ring
Price Range Ex VAT: 50 - 100
