Ring Video Doorbell
See, hear and speak to anyone at your door from your smartphone, tablet or PC. Works on every home - with or without a doorbell. Quick and easy self-install.
Answer the Door From Anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. Then use the free Ring app to see, hear and speak to guests from your smartphone, tablet or PC.
• Motion-activated alerts
• Crystal-clear 720HD video
• Two-way talk with noise cancellation
Never Miss a Visitor
Ring lets you customize your motion sensors, so you’ll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock – day or night, rain or shine.
• Custom motion zones
• Infrared night vision
• Lifetime purchase protection
Home Security at Your Fingertips
Power your Video Doorbell with its built-in rechargeable battery, or connect it to your existing doorbell wiring for a non-stop charge. It also comes with everything you need to install your Doorbell in just a few minutes, with no professional help required.
• Dual power options
• Simple installation and setup
• iOS, Android, Mac and Windows 10 compatible
A Ring of Security Around Your Home
With a Video Doorbell at your door and Stick Up Cams around the house, you can create a Ring of Security around your entire home, and get complete peace of mind for you and your family.
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
Answer the door from anywhere
Get instant alerts when visitors press your Doorbell or trigger the built-in motion sensors. -
Never miss a visitor
Ring lets you customize your motion sensors, so you'll always be the first to know when you have a visitor. With infrared night vision and a weather-resistant design, you can monitor your home around the clock - day or night, rain or shine. -
Home security at your fingertips
- Ring Video Doorbell - doorbell camera
- Product Type
- Doorbell camera
- Functions
- Motion detection, camera
- Power Source
- Hardwired, battery
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- Supported Host Device OS
- iOS, Android, Windows, MacOS
- Camera
- Audio - Day&Night
- Satin nickel
- 2 year warranty
- 6.17 cm x 2.21 cm x 12.65 cm
- Product Type
- Doorbell camera
- Functions
- Power Source
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- OS Required
- Apple MacOS, Android, Apple iOS, Windows 10
- Weatherproof, instant alerts 720p resolution support
Camera
- Day & Night Functionality
- Audio Support
- Video Modes
- 720p
- Motion Detection Technology, 2-way voice communication, 180° field of view
Motion Sensor
- Automatic night vision, custom motion zones
- Satin nickel
- Nominal Voltage
- DC 8 - 24 V
- Warranty
- 2 year warranty
- 6.17 cm
- 2.21 cm
- 12.65 cm
- -20 °C
- 48 °C
