A flexible, weather-resistant outdoor security camera that puts pro-grade security exactly where you need it. Stick it up anywhere you want to see and hear more with advanced features like 3D Motion Detection, HDR video, and Audio+.
Plug-In power means non-stop peace of mind. Place Stick Up Cam Pro on a flat surface for flexibility, or put it on the wall or ceiling with the included camera mount for a more permanent solution.
Weather resistant design
Built to withstand the elements, this outdoor camera offers peace of mind in any weather condition, ensuring continuous surveillance of your home's exterior. -
Enhanced security features
Equipped with 3D Motion Detection and Bird's Eye View, the camera provides precise monitoring and tracking of any activity around your property, offering a new level of security. -
Superior night vision
With Color Night Vision and High Dynamic Range (HDR), capture clear, detailed videos in low light conditions, ensuring round-the-clock safety and security. -
Convenient two-way audio
The two-way audio capability allows for easy communication with visitors or intruders, directly through your smartphone, adding an extra layer of security without being physically present.
 - Ring Stick Up Cam Pro Plug-In - network surveillance camera
 - Network surveillance camera - fixed - outdoor - weather resistant
- Audio
 - Yes: two-way audio capability
- Camera Mount Type
 - Surface mount, wall mount, ceiling mount
 - 7 cm x 7 cm x 15.39 cm
 - White
- Connectivity Technology
 - Wireless
- Camera
 - Colour - Day&Night
- Max Resolution
 - 1920 x 1080
- Motion Detection
- Video Modes
 - 1080p
 - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
 - 1 - USB-C charge cable - external - 6 m
 - Live View Control, Smartphone Monitoring, High Dynamic Range (HDR), Colour Night Vision, 3D Motion Detection, Bird's Eye View, customisable motion zones, built-in siren (85 dB), Bird's Eye Zones
 - 1-year warranty
- Environmental Parameters (operating)
 - -20 °C - 48.5 °C
- Audio Support
- Camera Mount Type
 - Wireless
 - 7 cm
 - 7 cm
 - 15.39 cm
Camera
 - Colour - Day&Night - fixed - outdoor - weather resistant
- Max Digital Video Resolution
 - 1920 x 1080
- Motion Detection
- Video Modes
 - 1080p
- Digital Video Capture Resolution
 - 1920 x 1080
Lens Construction
- Horizontal Field of View (degree)
 - 139
- Vertical Field of View (degree)
 - 80
- Diagonal Field of View (degree)
 - 155
- Network Interface
- Ports
 - USB-C (power only) - 24-pin USB-C
- Included Accessories
 - Mounting kit, security sticker, power adapter
- Cables Included
 - 1 x USB-C charge cable - external - 6 m
 - White
- Power Device
 - Power adapter - external
 - Limited warranty - 1 year
 - -20 °C
 - 48.5 °C
