Ring Stick Up Cam Pro Plug-in - White
Quicklinx: HJ5MWS00 Mfr#: B09CJX4B8G
Type: Indoor Camera
Compatible With: Alexa
10 In Stock
£133.33 ex VAT
£159.99 inc VAT
A flexible, weather-resistant outdoor security camera that puts pro-grade security exactly where you need it. Stick it up anywhere you want to see and hear more with advanced features like 3D Motion Detection, HDR video, and Audio+.
Plug-In power means non-stop peace of mind. Place Stick Up Cam Pro on a flat surface for flexibility, or put it on the wall or ceiling with the included camera mount for a more permanent solution.
  • Weather resistant design
    Built to withstand the elements, this outdoor camera offers peace of mind in any weather condition, ensuring continuous surveillance of your home's exterior.
  • Enhanced security features
    Equipped with 3D Motion Detection and Bird's Eye View, the camera provides precise monitoring and tracking of any activity around your property, offering a new level of security.
  • Superior night vision
    With Color Night Vision and High Dynamic Range (HDR), capture clear, detailed videos in low light conditions, ensuring round-the-clock safety and security.
  • Convenient two-way audio
    The two-way audio capability allows for easy communication with visitors or intruders, directly through your smartphone, adding an extra layer of security without being physically present.
Ring Stick Up Cam Pro Plug-In - network surveillance camera
Network surveillance camera - fixed - outdoor - weather resistant
Audio
Yes: two-way audio capability
Camera Mount Type
Surface mount, wall mount, ceiling mount
7 cm x 7 cm x 15.39 cm
White
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - USB-C charge cable - external - 6 m
Live View Control, Smartphone Monitoring, High Dynamic Range (HDR), Colour Night Vision, 3D Motion Detection, Bird's Eye View, customisable motion zones, built-in siren (85 dB), Bird's Eye Zones
1-year warranty
Environmental Parameters (operating)
-20 °C - 48.5 °C
Audio Support
Camera Mount Type
Wireless
7 cm
7 cm
15.39 cm
Camera
Colour - Day&Night - fixed - outdoor - weather resistant
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Horizontal Field of View (degree)
139
Vertical Field of View (degree)
80
Diagonal Field of View (degree)
155
Network Interface
Ports
USB-C (power only) - 24-pin USB-C
Mounting kit, security sticker, power adapter
1 x USB-C charge cable - external - 6 m
White
Power adapter - external
Limited warranty - 1 year
-20 °C
48.5 °C
Type: Indoor Camera
Brand: Ring
