Ring Stick Up Cam Pro Battery - White
Quicklinx: HJCZWS00 Mfr#: B09CJYHFVM
Type: Outdoor Camera
Compatible With: Alexa
£133.33 ex VAT
£159.99 inc VAT
A flexible, weather-resistant outdoor security camera that puts pro-grade security exactly where you need it. Stick it up anywhere you want to see and hear more with advanced features like 3D Motion Detection, HDR video, and Audio+.
The wire-free design of Stick Up Cam Pro Battery lets you place it on a flat surface for flexibility, or put it on the wall or ceiling with the included camera mount for a more permanent solution.
  • Weatherproof design
    Designed to withstand the elements, this camera operates in a wide range of temperatures from -20 °C to 48.5 °C, ensuring reliable surveillance in extreme weather conditions.
  • Enhanced connectivity
    With support for IEEE 802.11b/g/n Wi-Fi standards, this camera ensures a stable and secure connection to your home network for seamless remote monitoring.
  • Advanced surveillance features
    Equipped with 3D Motion Detection and Bird's Eye View, the camera provides precise motion tracking and a comprehensive overview of your property for enhanced security.
  • Superior night vision
    Features like Color Night Vision and High Dynamic Range (HDR) deliver clear and detailed images even in low-light conditions, ensuring round-the-clock surveillance.
  • Smart home integration
    Compatible with Alexa, this camera integrates seamlessly into your smart home ecosystem, allowing for voice-activated controls and alerts for a more convenient monitoring experience.
Ring Stick Up Cam Pro Battery - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: two-way audio capability
Camera Mount Type
Wall mount, ceiling mount
7 cm x 7 cm x 15.39 cm
White
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa
1 - USB power cable
3D Motion Detection, High Dynamic Range (HDR), Bird's Eye View, Colour Night Vision, Smartphone Monitoring, customisable motion zones, Motion Zone Alert, built-in siren (85 dB), remote siren operation
1-year warranty
Environmental Parameters (operating)
-20 °C - 48.5 °C
Audio Support
Camera Mount Type
Wireless
7 cm
7 cm
15.39 cm
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Horizontal Field of View (degree)
139
Vertical Field of View (degree)
80
Diagonal Field of View (degree)
155
Network Interface
Ports
USB (power only)
Mounting kit, USB cable, security sticker, battery
1 x USB power cable
White
Software Included
Ring Protect (30 days trial)
Internet of Things (IoT)
Alexa
Limited warranty - 1 year
-20 °C
48.5 °C
Brand: Ring
