Get non-stop power for non-stop peace of mind with a motion-activated camera that goes anywhere, inside or out. It installs in minutes and plugs into standard UK power sockets, so you’ll never have to worry about charging a battery. Place it on a flat surface for flexibility or on a wall for a secure mount. Wherever you are, Stick Up Cam Plug-In lets you check in on your home at any time.
Goes everywhere. Sees everything.
With countless placement options and customisable motion settings, find the perfect setup for you and your home.
Cover Every Corner
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control from the Ring app.
The Ring app unlocks all the features your devices have to offer so you can protect your home, your way.
Goes everywhere
Add eyes and ears inside or out with the versatile camera that goes almost anywhere. With countless placement options and customizable motion settings, you can find your perfect setup for you and your home. -
Complete control
Receive real-time notifications on your phone and tablet whether you're on the couch, at the gym or in the office. -
Works with Stick Up Cam
Do more with Stick Up Cam and connect it to an array of compatible devices for a smarter, more secure home.
- Ring Stick Up Cam Plug-In - 3rd Generation - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - weatherproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Wall mount, ceiling mount
- 6 cm x 6 cm x 9.7 cm
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a
- Cables Included
- 1 - micro-USB cable - external
- Voltage
- USB / AC Power
- Audio Noise Reduction
- 1-year warranty
- Environmental Parameters (operating)
- -20.5 °C - 48.5 °C
- Audio Support
- Camera Mount Type
- Wired, wireless
- 6 cm
- 6 cm
- 9.7 cm
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor, indoor - weatherproof
- Motion Detection
- Video Modes
- 1080p
Lens Construction
- Horizontal Field of View (degree)
- 110
- Vertical Field of View (degree)
- 57
- Diagonal Field of View (degree)
- 130
- Network Interface
- Ports
- LAN/power
- Included Accessories
- Base cover, 2 power adapters, security sticker, base pad
- Cables Included
- 1 x micro-USB cable - external
- White
- Power Requirements
- USB / AC
- Limited warranty - parts - 1 year
- -20.5 °C
- 48.5 °C
