Ring Stick up Cam Plug-in - Black
Quicklinx: FXW2WS00 Mfr#: B07VHXYGBR
Type: Indoor Camera
Compatible With: Alexa
17 In Stock
£74.99 ex VAT
£89.98 inc VAT
Express delivery Order within the next 4 hours for delivery tomorrow
Get non-stop power for non-stop peace of mind with a motion-activated camera that goes anywhere, inside or out. It installs in minutes and plugs into standard UK power sockets, so you’ll never have to worry about charging a battery. Place it on a flat surface for flexibility or on a wall for a secure mount. Wherever you are, Stick Up Cam Plug-In lets you check in on your home at any time.
Goes everywhere. Sees everything.
With countless placement options and customisable motion settings, find the perfect setup for you and your home.
Cover Every Corner
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control from the Ring app.
The Ring app unlocks all the features your devices have to offer so you can protect your home, your way.
  • Goes everywhere
    Add eyes and ears inside or out with the versatile camera that goes almost anywhere. With countless placement options and customizable motion settings, you can find your perfect setup for you and your home.
  • Complete control
    Receive real-time notifications on your phone and tablet whether you're on the couch, at the gym or in the office.
  • Works with Stick Up Cam
    Do more with Stick Up Cam and connect it to an array of compatible devices for a smarter, more secure home.
Ring Stick Up Cam Plug-In - 3rd Generation - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio
Yes: two-way audio capability
Camera Mount Type
Wall mount, ceiling mount
6 cm x 6 cm x 9.7 cm
Wired, wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Audio Noise Reduction
1-year warranty
Environmental Parameters (operating)
-20 °C - 50 °C
Audio Support
Camera Mount Type
Wired, wireless
6 cm
6 cm
9.7 cm
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor, indoor - weatherproof
Motion Detection
Video Modes
1080p
Lens Construction
Horizontal Field of View (degree)
110
Vertical Field of View (degree)
57
Diagonal Field of View (degree)
130
Network Interface
Security sticker, screws
Power adapter
Limited warranty - parts - 1 year
-20 °C
50 °C
Type: Indoor Camera
Brand: Ring
