Ring Spotlight Cam Plus - Battery - White
Quicklinx: H6Q2WS00 Mfr#: B09K1LWPRK
49 In Stock
£124.99 ex VAT
£149.98 inc VAT
Protect every corner of your home with spotlight cam battery, a versatile wire-free HD security camera that lets you see, hear and speak to anyone on your property from your phone, tablet and PC.
Adjustable motion sensors let you get the ideal setting for you and your home. With instant motion-activated alerts, you'll always be the first to know when there's someone on your property.
A built-in spotlight gives you crisp video around the clock, and night vision has you covered, even with the lights off. For added security, there's a 110-decibel alarm to help you scare off intruders.
With an adjustable mount and wire-free design, spotlight cam battery installs in any location. The quick-release rechargeable battery pack lets you easily charge your cam without moving the device.
With a video doorbell at your door and spotlight cams around the house, you can create a ring of security around your entire home, and get complete peace of mind for you and your family.
  • Weather resistant design
    Built to withstand the elements, this outdoor camera operates seamlessly in temperatures ranging from -20.5 °C to 48.5 °C, ensuring reliable security regardless of the weather conditions.
  • Advanced motion detection
    Equipped with 3D Motion Detection and customizable motion zones, this camera captures the slightest movements, offering enhanced security by sending motion-activated notifications directly to your device.
  • Reliable connectivity
    Featuring Wi-Fi compatibility with IEEE 802.11b/g/n networks, this camera ensures a stable and secure connection, enabling you to monitor your property from anywhere.
  • Innovative night vision
    With Color Night Vision, LED motion-activated lights, and a built-in siren, this camera provides exceptional surveillance capabilities, day and night, illuminating your property and deterring potential intruders.
  • Two-way audio communication
    This camera supports two-way audio, allowing you to communicate with visitors or potential intruders from anywhere, adding an extra layer of security to your home monitoring system.
Ring Spotlight Cam Plus Battery - network surveillance camera
Network surveillance camera - fixed - outdoor - weather resistant
Audio
Yes: two-way audio capability
Camera Mount Type
Surface mount, wall mount
7.6 cm x 8 cm x 12.6 cm
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa
1 - micro-USB charging cable
Built-in siren, LED motion-activated lights, motion-activated notifications, Colour Night Vision, customisable motion zones, Full-time Live View, 3D Motion Detection, Bird's Eye View
1-year warranty
Environmental Parameters (operating)
-20.5 °C - 48.5 °C
Audio Support
Camera Mount Type
Wireless
7.6 cm
8 cm
12.6 cm
Camera
Colour - Day&Night - fixed - outdoor - weather resistant
Motion Detection
Video Modes
1080p
Lens Construction
Horizontal Field of View (degree)
140
Network Interface
Ports
USB - Mini-USB Type B
Camera mount base, quick release battery pack, security sticker
1 x micro-USB charging cable
White
1
Internet of Things (IoT)
Alexa
Limited warranty - 1 year
-20.5 °C
48.5 °C
