Protect every corner of your home with spotlight cam battery, a versatile wire-free HD security camera that lets you see, hear and speak to anyone on your property from your phone, tablet and PC.
Adjustable motion sensors let you get the ideal setting for you and your home. With instant motion-activated alerts, you'll always be the first to know when there's someone on your property.
A built-in spotlight gives you crisp video around the clock, and night vision has you covered, even with the lights off. For added security, there's a 110-decibel alarm to help you scare off intruders.
With an adjustable mount and wire-free design, spotlight cam battery installs in any location. The quick-release rechargeable battery pack lets you easily charge your cam without moving the device.
With a video doorbell at your door and spotlight cams around the house, you can create a ring of security around your entire home, and get complete peace of mind for you and your family.
Weather resistant design
Built to withstand the elements, this outdoor camera operates seamlessly in temperatures ranging from -20.5 °C to 48.5 °C, ensuring reliable security regardless of the weather conditions. -
Advanced motion detection
Equipped with 3D Motion Detection and customizable motion zones, this camera captures the slightest movements, offering enhanced security by sending motion-activated notifications directly to your device. -
Reliable connectivity
Featuring Wi-Fi compatibility with IEEE 802.11b/g/n networks, this camera ensures a stable and secure connection, enabling you to monitor your property from anywhere. -
Innovative night vision
With Color Night Vision, LED motion-activated lights, and a built-in siren, this camera provides exceptional surveillance capabilities, day and night, illuminating your property and deterring potential intruders. -
Two-way audio communication
This camera supports two-way audio, allowing you to communicate with visitors or potential intruders from anywhere, adding an extra layer of security to your home monitoring system.
- Ring Spotlight Cam Plus Battery - network surveillance camera
- Network surveillance camera - fixed - outdoor - weather resistant
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Surface mount, wall mount
- 7.6 cm x 8 cm x 12.6 cm
- Black
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Intelligent Assistant
- Alexa
- Cables Included
- 1 - micro-USB charging cable
- Built-in siren, LED motion-activated lights, motion-activated notifications, Colour Night Vision, customisable motion zones, Full-time Live View, 3D Motion Detection, Bird's Eye View
- 1-year warranty
- Environmental Parameters (operating)
- -20.5 °C - 48.5 °C
- Audio Support
- Camera Mount Type
- Wireless
- 7.6 cm
- 8 cm
- 12.6 cm
Camera
- Colour - Day&Night - fixed - outdoor - weather resistant
- Motion Detection
- Video Modes
- 1080p
Lens Construction
- Horizontal Field of View (degree)
- 140
- Network Interface
- Ports
- USB - Mini-USB Type B
- Included Accessories
- Camera mount base, quick release battery pack, security sticker
- Cables Included
- 1 x micro-USB charging cable
- Black
- Power Device
- Battery
- Battery
- 1
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Limited warranty - 1 year
- -20.5 °C
- 48.5 °C
