Small Solar Panel helps charge any Ring USB-C Security Camera—or barrel plug Security Camera with the included USB-C to barrel plug adapter. Plus, its compact design makes it oh-so-easy to place or reposition. Mount horizontally, then use the adjustable arm with 180 degrees of tilt to get the perfect angle to maximise your solar power.
- For best performance, Ring recommends at least 2-3 hours of direct sunlight per day.
Efficient power supply
Designed specifically for smart security cameras, this solar panel and power adapter combination ensures your security system remains powered. With a 4 W output and a DC 5 V voltage supply, it provides a steady and reliable energy source. -
Durable design
Built to withstand the elements, this product features a durable design and a 180° tilt function. This flexibility allows for optimal positioning to capture sunlight, ensuring your security camera stays charged in various weather conditions. -
Convenient connectivity
The inclusion of a 2 m USB-C cable with a 24-pin USB-C output connector type offers easy and efficient connection to your smart security camera. This ensures a hassle-free setup and maintenance experience.
- Ring solar panel - USB-C - 4 watt
- Product Type
- Solar panel
- Designed For
- Smart security camera
- 16.9 cm x 1.2 cm x 20.5 cm
- White
- Output Connector Type
- USB-C
- Voltage Provided
- DC 5 V
- Power Provided
- 4 watt
- Cables
- USB-C cable - 2 m
- 1-year warranty
- Product Type
- Solar panel
- Designed For
- 16.9 cm
- 1.2 cm
- 20.5 cm
- Enclosure Colour
- White
- Voltage Provided
- DC 5 V
- Output connectors
- 24 pin USB-C
- Power Provided
- 4 watt
- 180° tilt, weatherproof
- Packaging Type
- Box
- Included Accessories
- USB-C to barrel-plug adapter, cable clips, screws, wall plugs, mounting base
- Cables Included
- USB-C cable - 2 m
- Limited warranty - 1 year
