Ring Solar Panel (USB-C) - White
Quicklinx: H58FWS00 Mfr#: B0B27MW1L7
Type: Solar Panel
Compatible With: [N/A]
More than 50 In Stock
£35.26 ex VAT
£42.31 inc VAT
Small Solar Panel helps charge any Ring USB-C Security Camera—or barrel plug Security Camera with the included USB-C to barrel plug adapter. Plus, its compact design makes it oh-so-easy to place or reposition. Mount horizontally, then use the adjustable arm with 180 degrees of tilt to get the perfect angle to maximise your solar power.
  • For best performance, Ring recommends at least 2-3 hours of direct sunlight per day.
  • Efficient power supply
    Designed specifically for smart security cameras, this solar panel and power adapter combination ensures your security system remains powered. With a 4 W output and a DC 5 V voltage supply, it provides a steady and reliable energy source.
  • Durable design
    Built to withstand the elements, this product features a durable design and a 180° tilt function. This flexibility allows for optimal positioning to capture sunlight, ensuring your security camera stays charged in various weather conditions.
  • Convenient connectivity
    The inclusion of a 2 m USB-C cable with a 24-pin USB-C output connector type offers easy and efficient connection to your smart security camera. This ensures a hassle-free setup and maintenance experience.
Ring solar panel - USB-C - 4 watt
Solar panel
Smart security camera
16.9 cm x 1.2 cm x 20.5 cm
White
Output Connector Type
USB-C
Voltage Provided
DC 5 V
Power Provided
4 watt
Cables
USB-C cable - 2 m
1-year warranty
Solar panel
16.9 cm
1.2 cm
20.5 cm
Enclosure Colour
White
Voltage Provided
DC 5 V
Output connectors
24 pin USB-C
Power Provided
4 watt
180° tilt, weatherproof
Packaging Type
Box
USB-C to barrel-plug adapter, cable clips, screws, wall plugs, mounting base
USB-C cable - 2 m
Limited warranty - 1 year
Type: Solar Panel
Brand: Ring
