Small Solar Panel helps charge any Ring USB-C Security Camera—or barrel plug Security Camera with the included USB-C to barrel plug adapter. Plus, its compact design makes it oh-so-easy to place or reposition. Mount horizontally, then use the adjustable arm with 180 degrees of tilt to get the perfect angle to maximise your solar power.
- For best performance, Ring recommends at least 2-3 hours of direct sunlight per day.
Efficient power supply
With a power output of 4 W and a voltage provision of DC 5 V, this solar panel ensures your smart security camera stays powered throughout the day without the need for direct electrical wiring. -
Durable design
Designed to withstand the elements, this solar panel is durable, making it an ideal outdoor power solution for your smart security camera. Its 180° tilt feature allows for optimal positioning towards the sun, ensuring maximum energy absorption. -
Convenient connectivity
Comes equipped with a 2 m long USB-C cable, providing flexible placement options and easy connection to your smart security camera. The 24-pin USB-C output connector ensures a secure and stable power supply.
 - Ring solar panel - 24 pin USB-C - 4 Watt
- Product Type
 - Solar panel
 - 16.9 cm x 1.2 cm x 20.5 cm
 - Black
- Output Connector Type
 - 24 pin USB-C
- Voltage Provided
 - DC 5 V
- Power Provided
 - 4 Watt
- Cables
 - USB-C cable - 2 m
 - 1-year warranty
- Product Type
 - Solar panel
- Designed For
 - Smart security camera
 - 16.9 cm
 - 1.2 cm
 - 20.5 cm
- Enclosure Colour
 - Black
- Voltage Provided
 - DC 5 V
- Output connectors
 - 24 pin USB-C
- Power Provided
 - 4 Watt
 - 180° tilt, weatherproof
- Packaging Type
 - Box
- Included Accessories
 - USB-C to barrel-plug adapter, cable clips, screws, wall plugs, mounting base
- Cables Included
 - USB-C cable - 2 m
 - Limited warranty - 1 year
