Ring Solar Panel (USB-C) - Black
Quicklinx: H58DWS00 Mfr#: B0B27HR4KY
Type: Solar Panel
Compatible With: [N/A]
More than 50 In Stock
£36.01 ex VAT
£43.21 inc VAT
Small Solar Panel helps charge any Ring USB-C Security Camera—or barrel plug Security Camera with the included USB-C to barrel plug adapter. Plus, its compact design makes it oh-so-easy to place or reposition. Mount horizontally, then use the adjustable arm with 180 degrees of tilt to get the perfect angle to maximise your solar power.
  • For best performance, Ring recommends at least 2-3 hours of direct sunlight per day.
  • Efficient power supply
    With a power output of 4 W and a voltage provision of DC 5 V, this solar panel ensures your smart security camera stays powered throughout the day without the need for direct electrical wiring.
  • Durable design
    Designed to withstand the elements, this solar panel is durable, making it an ideal outdoor power solution for your smart security camera. Its 180° tilt feature allows for optimal positioning towards the sun, ensuring maximum energy absorption.
  • Convenient connectivity
    Comes equipped with a 2 m long USB-C cable, providing flexible placement options and easy connection to your smart security camera. The 24-pin USB-C output connector ensures a secure and stable power supply.
Ring solar panel - USB-C - 4 watt
Solar panel
Smart security camera
16.9 cm x 1.2 cm x 20.5 cm
Output Connector Type
USB-C
Voltage Provided
DC 5 V
Power Provided
4 watt
Cables
USB-C cable - 2 m
1-year warranty
Solar panel
16.9 cm
1.2 cm
20.5 cm
Enclosure Colour
Voltage Provided
DC 5 V
Output connectors
24 pin USB-C
Power Provided
4 watt
180° tilt, weatherproof
Packaging Type
Box
USB-C to barrel-plug adapter, cable clips, screws, wall plugs, mounting base
USB-C cable - 2 m
Limited warranty - 1 year
Type: Solar Panel
Brand: Ring
