Get an additional easy-to-use rechargeable Quick Release Battery, and make sure your Ring devices are always ready to protect your home, without the need for hardwiring.
Nonstop Battery Power: When the battery pack in your Ring device runs low, replace it with a spare Quick Release Battery for nonstop power. Recharging is easy, simply press the tab to release from your device, then connect to a power supply with a micro-USB cable to begin charging. Swaps in and out of your device with a quick-release tab Charges using a micro-USB cable Can last for months between charges, depending on usage and weather
Efficient power
Equipped with lithium-ion technology, this battery pack offers efficient and reliable power for your camera and video doorbell, ensuring they remain operational for longer periods without the need for frequent recharging. -
Easy installation
The Quick-Release Battery Pack is designed for easy installation, allowing for a hassle-free setup with its 5-pin Micro-USB Type-B input connector. This design ensures you can quickly power your devices without complicated procedures.
- Ring Quick-Release Battery Pack battery - Li-Ion
- Product Type
- Battery
- Designed For
- Camera, video doorbell
- 4.5 cm x 2.25 cm x 7 cm
- Grey
- Battery
- Lithium Ion
- 1-year warranty
- Product Type
- Battery
- Designed For
- 4.5 cm
- 2.25 cm
- 7 cm
- Enclosure Colour
- Grey
- Input Connectors
- 5 pin Micro-USB Type B
- Technology
- Lithium Ion
- Limited warranty - 1 year , Limited warranty - money back guarantee - 30 days
Ring Quick Release battery pack
