Ring Quick Release battery pack
Quicklinx: GBQ8WS00 Mfr#: B07CW6ZR3Q
Type: Battery Pack
Compatible With: Alexa
Hurry, only 1 left in stock!
£19.16 ex VAT
£22.99 inc VAT
Express delivery Order within the next 3 hours for delivery on Tuesday
Get an additional easy-to-use rechargeable Quick Release Battery, and make sure your Ring devices are always ready to protect your home, without the need for hardwiring.
Nonstop Battery Power: When the battery pack in your Ring device runs low, replace it with a spare Quick Release Battery for nonstop power. Recharging is easy, simply press the tab to release from your device, then connect to a power supply with a micro-USB cable to begin charging. Swaps in and out of your device with a quick-release tab Charges using a micro-USB cable Can last for months between charges, depending on usage and weather
  • Efficient power
    Equipped with lithium-ion technology, this battery pack offers efficient and reliable power for your camera and video doorbell, ensuring they remain operational for longer periods without the need for frequent recharging.
  • Easy installation
    The Quick-Release Battery Pack is designed for easy installation, allowing for a hassle-free setup with its 5-pin Micro-USB Type-B input connector. This design ensures you can quickly power your devices without complicated procedures.
Ring Quick-Release Battery Pack battery - Li-Ion
Camera, video doorbell
4.5 cm x 2.25 cm x 7 cm
Grey
Lithium Ion
1-year warranty
4.5 cm
2.25 cm
7 cm
Enclosure Colour
Grey
Input Connectors
5 pin Micro-USB Type B
Lithium Ion
Limited warranty - 1 year , Limited warranty - money back guarantee - 30 days
Type: Battery Pack
Brand: Ring
