Ring Indoor Camera (2nd gen) - White
Quicklinx: H8ZGWS00 Mfr#: B0B6GKH3C2
Type: Indoor Camera
Compatible With: Alexa
Colours:
40 left in stock
£37.49 ex VAT
£44.98 inc VAT
Express delivery Order within the next 17 hours for delivery on Monday
Get the whole picture about what's happening inside your home, or keep the picture private by using the manual, removable Privacy Cover to turn off audio and video with a simple swivel. Versatile protection and personalised peace of mind - that’s Indoor Camera (2nd Gen). The ideal way to check in on your home from wherever you are, Indoor Camera (2nd Gen) is a versatile plug-in Security Camera, designed to go almost anywhere indoors.
Easy to install and with a compact design, Indoor Camera (2nd Gen) simply plugs in to a standard electrical socket, so you can add protection wherever you need it inside your home.
Type: Indoor Camera
Brand: Ring
Stock Status: While stocks last
Stock Status: Clearance
