Ring Indoor Cam
Quicklinx: FN3GWS00 Mfr#: 8SN1S9-WEU0
Type: Indoor Camera
Compatible With: Alexa
Colours:
£41.66 ex VAT
£49.99 inc VAT
A compact camera that brings smart security inside, Indoor Cam is your solution to easily check what’s happening at home. It’s small enough to go almost anywhere, and its simple plug-in installation means you’ll have peace of mind in no time. Place a few inside to cover your entire home, and save on security with a bundle.
Small in size. Big on peace of mind.
Bring protection inside with the mini marvel that packs a powerful punch. The perfect combination of tiny and mighty, Indoor Cam comes with all the features to keep you connected to home – HD video, two-way talk and motion-activated notifications – in a compact form fit for the smallest of spaces.
See your home. Away from home.
Watch what happens - Check to see what’s happening at home from anywhere, at any time.
Right from your phone - Link your Indoor Cams together to control them all from a single dashboard.
Cover every corner.
Put one in the living room to watch over your pets. Another in the hallway to see who comes and goes. Put one near the back door and always know who’s moving between inside and out.
Complete control. One simple app.
Connected Devices - Connect to all your Ring devices to see what’s happening from a single dashboard and to control everything from one simple app.
  • Wide coverage
    With an angular field of view reaching 140 degrees diagonally, 115 degrees horizontally, and 60 degrees vertically, the Ring Indoor Cam ensures comprehensive coverage of your indoor space, making no corner too obscure to be seen.
  • Enhanced connectivity
    Equipped with IEEE 802.11b, g, n network interfaces and Wi-Fi capabilities, this camera offers seamless integration into your existing home network for a reliable, wireless connection.
  • Advanced surveillance
    Featuring 1080p video modes, two-way audio capability, and day and night functionality, the Ring Indoor Cam provides high-quality, round-the-clock surveillance with the added benefit of noise-canceling to ensure clear audio.
  • Smart detection
    Motion Detection technology allows the Ring Indoor Cam to intelligently detect activity in your home, sending alerts directly to your device for immediate awareness and peace of mind.
Ring Indoor Cam - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Surface mount, wall mount
4.58 cm x 4.58 cm x 7.5 cm
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Live View Control, built-in siren, noise-cancellation, instant notification
1-year warranty
Environmental Parameters (operating)
-5 °C - 45 °C
Audio Support
Camera Mount Type
Wireless
4.58 cm
4.58 cm
7.5 cm
Europe
Camera
Colour - Day&Night - fixed - indoor
Motion Detection
Video Modes
1080p
Lens Construction
Horizontal Field of View (degree)
115
Vertical Field of View (degree)
60
Diagonal Field of View (degree)
140
Network Interface
Wall mount kit, security sticker
White
Power Requirements
DC 5 V - 2 A
Power adapter - external AC 120/230 V
Android 5.0 or later, Apple iOS 9.3 or later
Limited warranty - parts - 1 year
Shipping Width
14.958 cm
Shipping Depth
6.24 cm
Shipping Height
18.127 cm
Shipping Weight
700 g
-5 °C
45 °C
Type: Indoor Camera
Brand: Ring
