A compact camera that brings smart security inside, Indoor Cam is your solution to easily check what’s happening at home. It’s small enough to go almost anywhere, and its simple plug-in installation means you’ll have peace of mind in no time. Place a few inside to cover your entire home, and save on security with a bundle.
Small in size. Big on peace of mind.
Bring protection inside with the mini marvel that packs a powerful punch. The perfect combination of tiny and mighty, Indoor Cam comes with all the features to keep you connected to home – HD video, two-way talk and motion-activated notifications – in a compact form fit for the smallest of spaces.
See your home. Away from home.
Watch what happens - Check to see what’s happening at home from anywhere, at any time.
Right from your phone - Link your Indoor Cams together to control them all from a single dashboard.
Cover every corner.
Put one in the living room to watch over your pets. Another in the hallway to see who comes and goes. Put one near the back door and always know who’s moving between inside and out.
Complete control. One simple app.
Connected Devices - Connect to all your Ring devices to see what’s happening from a single dashboard and to control everything from one simple app.
Wide coverage
With an angular field of view reaching 140 degrees diagonally, 115 degrees horizontally, and 60 degrees vertically, the Ring Indoor Cam ensures comprehensive coverage of your indoor space, making no corner too obscure to be seen. -
Enhanced connectivity
Equipped with IEEE 802.11b, g, n network interfaces and Wi-Fi capabilities, this camera offers seamless integration into your existing home network for a reliable, wireless connection. -
Advanced surveillance
Featuring 1080p video modes, two-way audio capability, and day and night functionality, the Ring Indoor Cam provides high-quality, round-the-clock surveillance with the added benefit of noise-canceling to ensure clear audio. -
Smart detection
Motion Detection technology allows the Ring Indoor Cam to intelligently detect activity in your home, sending alerts directly to your device for immediate awareness and peace of mind.
- Ring Indoor Cam - network surveillance camera
- Network surveillance camera - fixed - indoor
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- Camera Mount Type
- Surface mount, wall mount
- 4.58 cm x 4.58 cm x 7.5 cm
- White
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Live View Control, built-in siren, noise-cancellation, instant notification
- 1-year warranty
- Environmental Parameters (operating)
- -5 °C - 45 °C
- Audio Support
- Camera Mount Type
- Wireless
- 4.58 cm
- 4.58 cm
- 7.5 cm
- Localisation
- Europe
Camera
- Colour - Day&Night - fixed - indoor
- Motion Detection
- Video Modes
- 1080p
Lens Construction
- Horizontal Field of View (degree)
- 115
- Vertical Field of View (degree)
- 60
- Diagonal Field of View (degree)
- 140
- Network Interface
- Included Accessories
- Wall mount kit, security sticker
- White
- Power Requirements
- DC 5 V - 2 A
- Power Device
- Power adapter - external AC 120/230 V
- OS Required
- Android 5.0 or later, Apple iOS 9.3 or later
- Limited warranty - parts - 1 year
- Shipping Width
- 14.958 cm
- Shipping Depth
- 6.24 cm
- Shipping Height
- 18.127 cm
- Shipping Weight
- 700 g
- -5 °C
- 45 °C
