Discover the Ring Floodlight Cam Wired Pro, an outdoor surveillance solution designed by Amazon.com. This network camera is engineered to enhance the security of your home or business with its array of features. Experience peace of mind with 1080p HD video capture, HDR, and Color Night Vision, ensuring clear and detailed footage day or night. The camera's 140° horizontal and 80° vertical field of view offers comprehensive coverage of your property.
Equipped with two LED floodlights producing 2000 lumens and a built-in siren of 110 dB, the Floodlight Cam Wired Pro deters intruders effectively. Advanced motion detection technologies, including 3D Motion Detection and radar sensor, provide precise alerts, while customizable motion zones ensure you're only notified when it matters. With two-way audio capability, you can communicate with visitors from anywhere.
Integration with Alexa makes this camera a seamless addition to your smart home ecosystem, offering voice control and intelligent automation. Its weather-resistant design ensures reliable operation in temperatures ranging from -20.5 °C to 48 °C, making it a versatile choice for outdoor security. Whether you're looking to protect your home or business, the Ring Floodlight Cam Wired Pro offers a powerful combination of technology and convenience.
Weather resistant design
Built to withstand the elements, this outdoor camera operates in a wide range of temperatures from -20.5 °C to 48 °C, ensuring reliable security through varying weather conditions. -
Enhanced security features
Equipped with 2 LED floodlights producing 2000 lumens, a built-in siren of 110 dB, and advanced motion detection capabilities including 3D Motion Detection and radar sensor, this camera provides comprehensive security coverage. -
Superior connectivity
Supports multiple IEEE 802.11 network interfaces including ac, b, g, and n, ensuring robust and reliable Wi-Fi connectivity for seamless video streaming. -
Innovative surveillance technology
Features like Audio+, Bird's Eye View, Color Night Vision, HDR, Live View Control, Smart Zoom, and advanced pre-roll enhance the surveillance experience with detailed and clear video capture, day or night. -
Smart home integration
Fully compatible with Alexa, this IoT-ready camera integrates seamlessly into your smart home ecosystem, allowing for voice control and smart automation for an enhanced user experience.
- Ring Floodlight Cam Wired Pro - network surveillance camera
- Network surveillance camera - fixed - outdoor - weather resistant
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Wall mount, ceiling mount
- 32.6 cm x 20.2 cm x 21.7 cm
- White
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Intelligent Assistant
- Alexa
- Voltage
- AC 100-240 V
- Radar sensor, HDR, Live View Control, Colour Night Vision, advanced pre-roll, built-in siren (110 dB), 2000 lumens floodlight sensor, 2 LED floodlight, Smart Zoom, Advanced Motion Detection, customisable motion zones, 3D Motion Detection, Bird's Eye View, Audio+, motion-activated notifications
- 1-year warranty
- Environmental Parameters (operating)
- -20.5 °C - 48 °C
- Audio Support
- Camera Mount Type
- Wireless
- 32.6 cm
- 20.2 cm
- 21.7 cm
Camera
- Colour - Day&Night - fixed - outdoor - weather resistant
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Video Capture Resolution
- 1920 x 1080
Lens Construction
- Horizontal Field of View (degree)
- 140
- Vertical Field of View (degree)
- 80
- Network Interface
- Included Accessories
- Mounting bracket, screws, installation accessories
- White
- Power Device
- Power adapter AC 100-240 V
- Software Included
- Ring Protect (30 days trial), Ring App
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Limited warranty - 1 year
- -20.5 °C
- 48 °C
