Hardwired for non-stop peace of mind, Ring Floodlight Cam Wired Plus offers reliable outdoor protection and advanced motion detection, day or night. Designed for larger areas of your home, such as driveways and gardens, Ring Floodlight Cam Wired Plus features a remote-activated security siren and LED floodlights for protection when you need it, and extra visibility at night. Customisable Motion Zones let you focus your security on the areas of your property that matter most.
Enhanced security
The Ring Floodlight Cam Wired Plus is designed for outdoor use with weatherproof protection, ensuring it remains operational in various environmental conditions from -20°C and beyond. Its robust design makes it an ideal choice for monitoring and securing the exterior of your home. -
Advanced connectivity
Equipped with IEEE 802.11b/g/n network interfaces and Wi-Fi capabilities, this device ensures a reliable and seamless connection to your home network, allowing for real-time monitoring and alerts. -
Intelligent integration
With Alexa compatibility, the Floodlight Cam Wired Plus integrates smoothly into your smart home ecosystem, enabling voice commands for easy operation and enhanced home automation. -
Superior surveillance
Featuring 1080p video modes, color imaging, day and night functionality, and two-way audio capability, this camera offers high-quality surveillance. The motion-activated floodlight adds an extra layer of security, illuminating the area and capturing clear video footage even in low light conditions.
- Ring Floodlight Cam Wired Plus - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Ceiling mount, wall mount
- 28 cm x 21 cm x 17.8 cm
- 2.04 kg
- Black
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Intelligent Assistant
- Alexa
- Voltage
- AC 120/230 V
- Motion sensor, built-in siren, motion activated floodlight, Colour Night Vision
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Audio Support
- Camera Mount Type
- Wireless
- 28 cm
- 21 cm
- 17.8 cm
- 2.04 kg
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Video Modes
- 1080p
Lens Construction
- Horizontal Field of View (degree)
- 140
- Vertical Field of View (degree)
- 80
- Network Interface
- FCC Part 15 B, FCC Part 15 C, FCC Part 15 E, SAR, UL
- Black
- Power Requirements
- AC 120/230 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Limited warranty - 1 year
- Shipping Width
- 29.2 cm
- Shipping Depth
- 17.3 cm
- Shipping Height
- 25.6 cm
- Shipping Weight
- 2.31 kg
- -20 °C
- 50 °C
