Ring Floodlight Cam Pro - White
Quicklinx: GBQDWS00 Mfr#: B08FCTSMQN
Type: Floodlight
Compatible With: Alexa
£183.33 ex VAT
£219.99 inc VAT
Protect your home with the motion-activated security camera with built-in floodlights, a siren alarm and two-way audio, so you can see, hear and speak to anyone on your property from anywhere.
  • Premium features, perpetual protection
    Hardwired for reliable performance day or night. Floodlight Cam Wired Pro is a brighter, clearer solution for security around your home.
  • Outdoor security with an extra dimension
    Pinpoint when and where a motion event begins with 3D Motion Detection and Bird's Eye View.
  • Accurate motion detection, even at a distance
    Add distance, speed, size and trajectory perception to detect visitors more accurately, giving you motion alerts with extra precision.
  • Bird's Eye View
    Provides an aerial map view of your property showing you the historical context of the motion event.
  • All-weather motion detection
    In good weather or bad, Floodlight Cam Wired Pro helps you see what's happening outside your home and lets you know when someone visits your property for everyday peace of mind.
Ring Floodlight Cam Wired Pro - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: two-way audio capability, built-in microphone
Camera Mount Type
Wall mount, ceiling mount
32.6 cm x 20.2 cm x 21.7 cm
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Intelligent Assistant
Alexa
Voltage
AC 120/230 V
Smart Zoom, Smartphone Monitoring, High Dynamic Range (HDR), cloud recording, Colour Night Vision, instant notification, motion activated floodlight, built-in siren (110 dB), built-in 2 LED lights, 3D Motion Detection, Bird's Eye View, lamp brightness control
1-year warranty
Environmental Parameters (operating)
-20.5 °C - 48 °C
Audio Support
Camera Mount Type
Wireless
32.6 cm
20.2 cm
21.7 cm
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Motion Detection
Video Modes
1080p
Lens Construction
Horizontal Field of View (degree)
140
Vertical Field of View (degree)
80
Network Interface
White
Power Requirements
AC 120/230 V
Android 6.0 (Marshmallow) or later, Apple iOS 12 or later
Internet of Things (IoT)
Supported Host Device Platform
iOS, Android
Alexa
Limited warranty - 1 year
-20.5 °C
48 °C
Type: Floodlight
Brand: Ring
