Protect your home with the motion-activated security camera with built-in floodlights, a siren alarm and two-way audio, so you can see, hear and speak to anyone on your property from anywhere.
Premium features, perpetual protection
Hardwired for reliable performance day or night. Floodlight Cam Wired Pro is a brighter, clearer solution for security around your home. -
Outdoor security with an extra dimension
Pinpoint when and where a motion event begins with 3D Motion Detection and Bird's Eye View. -
Accurate motion detection, even at a distance
Add distance, speed, size and trajectory perception to detect visitors more accurately, giving you motion alerts with extra precision. -
Bird's Eye View
Provides an aerial map view of your property showing you the historical context of the motion event. -
All-weather motion detection
In good weather or bad, Floodlight Cam Wired Pro helps you see what's happening outside your home and lets you know when someone visits your property for everyday peace of mind.
- Ring Floodlight Cam Wired Pro - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: two-way audio capability, built-in microphone
- Camera Mount Type
- Wall mount, ceiling mount
- 32.6 cm x 20.2 cm x 21.7 cm
- White
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Intelligent Assistant
- Alexa
- Voltage
- AC 120/230 V
- Smart Zoom, Smartphone Monitoring, High Dynamic Range (HDR), cloud recording, Colour Night Vision, instant notification, motion activated floodlight, built-in siren (110 dB), built-in 2 LED lights, 3D Motion Detection, Bird's Eye View, lamp brightness control
- 1-year warranty
- Environmental Parameters (operating)
- -20.5 °C - 48 °C
- Audio Support
- Camera Mount Type
- Wireless
- 32.6 cm
- 20.2 cm
- 21.7 cm
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Motion Detection
- Video Modes
- 1080p
Lens Construction
- Horizontal Field of View (degree)
- 140
- Vertical Field of View (degree)
- 80
- Network Interface
- White
- Power Requirements
- AC 120/230 V
- OS Required
- Android 6.0 (Marshmallow) or later, Apple iOS 12 or later
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Supported Host Device Platform
- iOS, Android
- Alexa
- Limited warranty - 1 year
- -20.5 °C
- 48 °C
