Ring Chime Pro
Quicklinx: D39RWS00 Mfr#: 8AC4P6-0EU0
Type: Signal repeater / doorbell
Compatible With: Alexa, IFTTT, SmartThings
Stock Status: In Stock, Used Stock
Hurry, only 1 left in stock!
£40.84 ex VAT
£49.00 inc VAT
Express delivery Order within the next 13 hours for delivery tomorrow
Chime Pro
Wi-Fi extender and indoor Chime for Ring devices.
Wi-Fi Extender and Indoor Chime for Ring Devices
Chime Pro extends your Wi-Fi signal and amplifies your Ring alerts. Plug Chime Pro into any standard power outlet, link it to all your Ring devices, and get Ring alerts anywhere in your home.
- Boosts Ring's Network Signal
- Multiple Alert Tones
- Volume Control
- Do Not Disturb Mode
Extend Your Ring Network
Chime Pro extends the signal from your router to your Ring devices, so you can eliminate Wi-Fi dead zones and never miss a Ring alert.
Ring Chime PRO - signal repeater / doorbell
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
7.4 cm x 4.7 cm x 2.6 cm
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Volume adjustable
Nominal Voltage
AC 120/230 V
0.6 Watt
7.4 cm
4.7 cm
2.6 cm
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D39R 040161
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £28.45
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Compatible With: IFTTT
Compatible With: SmartThings
Brand: Ring
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
