Ring Chime Pro (Gen 2)
Quicklinx: GBQ9WS00 Mfr#: B087Q2MD5N
Type: Signal repeater / doorbell
Compatible With: Alexa
Hurry, only 1 left in stock!
£37.50 ex VAT
£45.00 inc VAT
Chime Pro extends your Wi-Fi signal and amplifies your Ring alerts. Plug Chime Pro into any standard power outlet, link it to all your Ring devices, and get Ring alerts anywhere in your home.
  • Enhanced connectivity
    The Chime PRO by Ring offers seamless wireless connectivity, supporting IEEE 802.11b, IEEE 802.11g, and IEEE 802.11n data link protocols. This ensures a reliable connection across various devices, enhancing the user experience by maintaining a stable network.
  • Customizable volume
    With its volume adjustable feature, the Chime PRO allows users to tailor sound levels to their preference. Whether preferring a louder chime to hear throughout the home or a softer tone to minimize disturbance, this device meets diverse needs.
Ring Chime PRO - Gen 2 - signal repeater / doorbell - 802.11a/b/g/n/ac - white
Environment
Indoor
Functions
Extending wireless transmission range
Integrated Components
Night light
Wireless - 802.11a/b/g/n/ac
Frequency Band
2.4 Ghz, 5 GHz
White
1-year warranty
6.9 cm x 2.9 cm x 10.3 cm
Environment
Indoor
Functions
Night light
Wireless - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 Ghz, 5 GHz
Volume adjustable
White
Warranty
1-year warranty
6.9 cm
2.9 cm
10.3 cm
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GBQ9 050609
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £26.37
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Ring
Stock Status: Used Stock
