Chime Pro extends your Wi-Fi signal and amplifies your Ring alerts. Plug Chime Pro into any standard power outlet, link it to all your Ring devices, and get Ring alerts anywhere in your home.
Enhanced connectivity
The Chime PRO by Ring offers seamless wireless connectivity, supporting IEEE 802.11b, IEEE 802.11g, and IEEE 802.11n data link protocols. This ensures a reliable connection across various devices, enhancing the user experience by maintaining a stable network. -
Customizable volume
With its volume adjustable feature, the Chime PRO allows users to tailor sound levels to their preference. Whether preferring a louder chime to hear throughout the home or a softer tone to minimize disturbance, this device meets diverse needs.
- Ring Chime PRO - Gen 2 - signal repeater / doorbell - 802.11a/b/g/n/ac - white
- Product Type
- Signal repeater / doorbell
- Environment
- Indoor
- Functions
- Extending wireless transmission range
- Integrated Components
- Night light
- Connectivity
- Wireless - 802.11a/b/g/n/ac
- Frequency Band
- 2.4 Ghz, 5 GHz
- White
- 1-year warranty
- 6.9 cm x 2.9 cm x 10.3 cm
- Product Type
- Environment
- Indoor
- Functions
- Night light
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 Ghz, 5 GHz
- Volume adjustable
- White
- Warranty
- 1-year warranty
- 6.9 cm
- 2.9 cm
- 10.3 cm
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GBQ9 050609 Condition: Customer return - item has been used and shows signs of use |
£24.10 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
