Ring Chime (Gen 2)
Ring Chime (Gen 2)
Quicklinx: H58CWS00 Mfr#: B09L45TSYF
Type: Doorbell chime
Compatible With: Alexa
Hurry, only 2 left in stock!
£23.34 ex VAT
£28.00 inc VAT
Hear notifications in your home when someone presses your doorbell or when motion is detected. Plug into standard wall sockets and connect Ring Chime to all your Ring Doorbells and Cameras.
Hear alerts loud and clear.
Ring Chime connects to all your Ring Video Doorbells and Security Cameras, so you can hear real-time notifications at home. Plus, the sleek design easily blends into any room.
Stay in tune in every room.
Place multiple Chime devices around your home to always hear notifications wherever you are. Whether you’re in the kitchen, office or bedroom, you’ll never miss a thing if your phone is out of reach.
  • Effortless connectivity
    With wireless connectivity technology, the Ring Chime (2nd Generation) seamlessly integrates into your home network, allowing for an easy setup process and immediate use. The device supports 802.11b/g/n protocols, ensuring compatibility with a wide range of wireless networks.
  • Customizable alerts
    The volume adjustable feature and LED indicator of the Ring Chime (2nd Generation) offer users the flexibility to customize alert sounds to their preference. Whether preferring a louder chime for larger homes or a softer tone for smaller spaces, this device meets various user needs.
  • Reliable operation
    Powered directly from a power socket, the Ring Chime (2nd Generation) ensures continuous operation without the need for battery replacements. This design choice ensures that your doorbell chime is always ready to alert you, providing peace of mind.
Ring Chime (2nd Generation) - doorbell chime - 802.11b/g/n - white
Doorbell chime
Power Source
Power socket
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
White
1-year warranty
6.2 cm x 2.5 cm x 7.78 cm
Doorbell chime
Power Source
Power socket
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Volume adjustable, LED indicator, audio alert
White
Warranty
1-year warranty
6.2 cm
2.5 cm
7.78 cm
Brand: Ring
