Ring Battery Video Doorbell Plus
Quicklinx: H7Q8WS00 Mfr#: B09WZBVWL9
Type: Smart doorbell
Compatible With: Alexa
£99.99 ex VAT
£119.98 inc VAT
See more of what’s happening and check in on packages left at your doorstep with Battery Video Doorbell Plus, featuring 1536p HD Live View and Head-To-Toe View.
From people to packages - see more
From food deliveries to an unwanted late-night visitor, with the advanced Battery Video Doorbell Plus you’ll see every detail with the expanded field of view of 1536p HD Video and you can respond right from the Ring app.
The more you see, the more you know.
Head-To-Toe View gives you an expanded field of view from your front door, so you can see more of every visitor and check on packages left at your doorstep and with the Package Detection feature (available with a Ring Protect subscription), you'll get real-time alerts whenever a package is detected.
Front door protection in high-definition.
Get a clear, high-definition view of whatever's happening at your door, even after dark, with 1536p HD Video and Colour Night Vision
  • Enhanced security
    With features like Advanced Motion Detection and customizable motion zones, the Ring Video Doorbell Plus ensures that your home security is personalized and responsive to your environment. The integration of a 2-way audio system, including a microphone and speaker, allows for clear communication with visitors or potential intruders, directly from your smartphone.
  • Reliable connectivity
    Leveraging wireless connectivity technology and supporting the IEEE 802.11b/g/n protocols, this smart doorbell ensures a reliable and seamless connection to your home network. Its compatibility with Alexa enhances your home automation experience, allowing for voice commands and real-time notifications.
  • All-weather reliability
    Designed to operate between -20.5°C and 50°C, the Ring Video Doorbell Plus is built to withstand extreme weather conditions, ensuring your home remains secure regardless of the climate.
  • Advanced video capabilities
    Featuring a 1536p video mode with a 150° field of view, both horizontally and vertically, the doorbell provides comprehensive coverage of your doorstep. Color Night Vision and Head to Toe Video capabilities ensure that you never miss a detail, day or night.
Ring Video Doorbell Plus - smart doorbell - 802.11b/g/n - satin nickel
Smart doorbell - with camera
Functions
Motion detection
Integrated Components
Microphone, speaker
Power Source
Hardwired, battery
Intelligent Assistant
Alexa
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Camera
Day&Night
Satin nickel
1-year warranty
6.2 cm x 2.8 cm x 12.8 cm
Functions
Motion detection
Microphone, speaker
Power Source
Hardwired, battery
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
2-way audio, real-time notifications, Quick Replies support, Package Alerts support
Internet of Things (IoT)
Alexa
Camera
Day & Night Functionality
Video Modes
1536p
Advanced Motion Detection, Live View Control, Colour Night Vision, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), Head to Toe Video
Rechargeable Battery
Rechargeable
Battery Included
USB charge cable, installation kit, security sticker, corner kit
Satin nickel
Warranty
1-year warranty
6.2 cm
2.8 cm
12.8 cm
-20.5 °C
50 °C
Brand: Ring
