Ring Battery Video Doorbell - Satin Nickel
Quicklinx: HVW8WS00 Mfr#: B0BZWQP9Z1
Type: Smart doorbell
Compatible With: Alexa
Colours:
Hurry, only 2 left in stock!
£83.33 ex VAT
£99.99 inc VAT
Express delivery Order within the next 18 hours for delivery on Friday
Wireless Video Doorbell with Head-To-Toe View.
  • Versatile power options
    The Ring Battery Video Doorbell is equipped with both hardwired and battery-powered options, enabling flexible installation that fits various home setups.
  • Superior video quality
    With a maximum digital video resolution of 1440 x 1440, this doorbell provides clear images, allowing for easy identification of visitors.
  • Enhanced visibility day and night
    Thanks to Color Night Vision technology, homeowners can enjoy a clear view of their entrance even in low light conditions, maximizing security.
  • Customizable detection settings
    Privacy and motion zones can be adjusted according to user preference, ensuring that only relevant activity is monitored.
  • Broad coverage with wide field of view
    The 150° horizontal and vertical field of view allows the doorbell to capture a wide area, providing coverage of the front entrance.
Ring Battery Video Doorbell - 2024 Edition - smart doorbell - 30-day free trial of Ring Home, DIY video, easy to install, head-to-toe view, easy to install - 802.11b/g/n - satin nickel
Smart doorbell - with camera
Functions
Motion detection
Power Source
Battery, hardwired
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Camera
Max Resolution 1440 x 1440 Day&Night
Satin nickel
1-year warranty
6.19 cm x 2.3 cm x 12.5 cm
Functions
Motion detection
Power Source
Battery, hardwired
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Two-way audio support
Camera
Day & Night Functionality
Max Digital Video Resolution
1440 x 1440
Privacy zones, Live View Control, Colour Night Vision, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), noise cancellation
Software
Ring Home (30 days trial)
USB-C cable, mounting bracket, mounting kit, security sticker
Satin nickel
AC 8 - 24 V
Warranty
1-year warranty
6.19 cm
2.3 cm
12.5 cm
-20 °C
50 °C
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HVW8 050534
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £33.13
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Ring
Stock Status: Used Stock
