Versatile power options
The Ring Battery Video Doorbell is equipped with both hardwired and battery-powered options, enabling flexible installation that fits various home setups. -
Superior video quality
With a maximum digital video resolution of 1440 x 1440, this doorbell provides clear images, allowing for easy identification of visitors. -
Enhanced visibility day and night
Thanks to Color Night Vision technology, homeowners can enjoy a clear view of their entrance even in low light conditions, maximizing security. -
Customizable detection settings
Privacy and motion zones can be adjusted according to user preference, ensuring that only relevant activity is monitored. -
Broad coverage with wide field of view
The 150° horizontal and vertical field of view allows the doorbell to capture a wide area, providing coverage of the front entrance.
- Ring Battery Video Doorbell - 2024 Edition - smart doorbell - 30-day free trial of Ring Home, DIY video, easy to install, head-to-toe view, easy to install - 802.11b/g/n - satin nickel
- Product Type
- Smart doorbell - with camera
- Functions
- Motion detection
- Power Source
- Battery, hardwired
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- Camera
- Max Resolution 1440 x 1440 Day&Night
- Satin nickel
- 1-year warranty
- 6.19 cm x 2.3 cm x 12.5 cm
- Product Type
- Functions
- Motion detection
- Power Source
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- Two-way audio support
Camera
- Day & Night Functionality
- Max Digital Video Resolution
- 1440 x 1440
- Privacy zones, Live View Control, Colour Night Vision, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), noise cancellation
Software
- Ring Home (30 days trial)
- Included Accessories
- USB-C cable, mounting bracket, mounting kit, security sticker
- Satin nickel
- Voltage Required
- AC 8 - 24 V
- Warranty
- 1-year warranty
- 6.19 cm
- 2.3 cm
- 12.5 cm
- -20 °C
- 50 °C
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HVW8 050534 Condition: Customer return - item has been opened but is in excellent condition |
£33.68 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
